iPad connection with smart case logon patch
Somebody informed me that smart car logon is also useable as iPad application. How smart case logon patch will be activated in my iPad so that I can use it properly?
Answered By 590495 points N/A #159500
I am having a hard time searching the web for SmartCase Logon but luckily I accidentally found which I think is the application you are looking for. But unfortunately the one I found is not meant for iPad device. The one I found is a PC version. If you are having a hard time on your present version of SmartCase Logon, try upgrading it to a much newer version. I’m sure this is not the latest version since the date it was released was a couple of years ago.
To download SmartCase Logon+ V2.2 to V2.2.1 Software patch, you may visit FUJITSU — SmartCase Logon+ V2.2 to V2.2.1 Software patch.
