No of visitors who read this post: 292
Type: Question
Your rating: None Average: 5 (1 vote)
I have windows XP installed and want to install IObit password protect folders software. So, I was hoping if someone will help me to search IObit password protect folders serial number. Any kind of help would be appreciated.
Comment viewing options
You can download IObit password protect folder software directly from IObit | Protected Folder - Folder/File lock and guard for PC Dummies. You can also acquire freeware password folder applications in the net.
All application for managing passwords is user-friendly. Protecting files is important and simple task if you have the right tool and it will not consume big space in your memory. Prevent unauthorized access to your important files, install one now.
