Invalid Argument When Trying to Add Photo Description
I would like to add a description to each of my photos. Whenever I select the “Edit File Information” button underneath my picture to add my description I receive a message saying:
“An error has occurred: (This text is only displayed to users in the group 'Root') 2 – implode(): Invalid arguments passed @ /var/www/coppermine/edit_one_pic.php line 116” My computer is using 1.5.18.
Why do I receive this error and how do I fix it?
Best Answer by Sharath Reddy
Answered By 0 points N/A #147039
Dear User,
This could a server-sided issue.
But try this to fix it
Open edit-one-pic.php
$keywords = explode($CONFIG['keyword_separator'], trim(html_entity_decode($keywords)));
And below add
$keywords_new = array();
Thank you.
Answered By 590495 points N/A #147040
Yes, I think so also. This error is probably from the web server of the website and affects most of the users accessing their account. If this is the first time that this happens, try adding the description after a couple of hours. We can also assume that this is also caused by heavy traffic due to the amount of users accessing the site.
Try doing it again after a couple of hours or maybe during off-peak hours to expect a much faster connection. You may also try contacting the customer support or the support personnel of the site to make them aware of the problem you are having regarding the images on your account. I’m sure they will check the system immediately.
