Morning to all gurus of errors,
Today I am here with a challenging error for all experts who think that they can solve any error problem.
As you can see there is no indication in this error image given below that which software error is this so I think it is tough to resolve such issue which has no clues.
A Runtime Error has occurred. Do you wish to Debug?
Line 221
Error: ‘something ‘is undefined
But I will give you a little clue while I was working on internet I had explored many webpages and I was downloading many software .exe files at a time. I was simultaneously running many .exe files to test them in the mean while this error appeared. Now I don’t know which .exe file caused this error. So,
now please tell me how to fix this error.
Hi Hope you are doing well.
Please follow below steps to solve your error. And please be reminded that you shall scan and detect whether your computer is infected by any worms or malwares or viruses before trying the below solution.
Thank you for your attention.
To resolve this problem, you have to click Start, then go to Control Panel. Make sure you are on Classic View, then find and open Internet options. Click the Advanced tab, then put a check on the check box for Disable script debugging (Internet Explorer) and Disable script debugging (Other).
Next, remove the check mark from the box for Display a notification about every script error. Click Apply first, then click OK. Please see screenshot.
