How can I integrate automatic clothing company bill template on my web shop? I want my online shoppers to get an automatic invoice after they check out using the template that I have downloaded online and have modified according to my company’s theme and logo. I want to do manual steps without adding or changing my store program which has an automatic check out notification on its own
Integrate automatic clothing company bill template in webshop
You can try Excel Invoice Template 1.6 which provides a free what-you-see-is-what-you-get form for invoices.
It offers a simple yet effective and professional-looking template that is ideal for small businesses.
I would also highly recommend FreshBooks which is the fastest method for you to get paid, invoicing your customers and tracking your business.
Another program would be Zoho Invoice which also has the capability of creating invoices easily.
Other invoicing programs you may also want to check are Invoicera and Sliq.
Hello Darlene Selvagio,
If you want to use an automated template then you can use it. All you need to do is to buy a template after that you have to do some of the changes in it according to your requirement. After that you have to make the index page into the header of your already running website. You have to change the menu bar according to your new template that you have made as your automated system. You can buy a template from the below link in a very cheap rate.
https://www.000webhost.com/
