Insufficient disk space! Error Appear
I am using Linux Operating system. I have almost 25 GB free space in C drive but I am receiving an error of low disk space, when I try to install BEA in my system. Then I chance directory or path but same error appears again. Please any one tell me its solution how can I remove this error.
Error
Insufficient disk space! The installer requires: 5MB for the BEA Home at /User/Klby/bea and 492MB temporary work space at /Users/kelby/Desktop/server900_linux32.bin Folder.
This is only 492MB available at /.
Answered By 0 points N/A #120986
Yes this is an error that we see much at the time of computing and we are very familiar with it. All kinds of operating system windows, Linux, apple whatever it is, this error is common for all of them. Especially we see this error most of the time of copy/past content.
This is not a software problem or not a hardware problem. Even it is not an error at all. It is a warning message. It gives you a message that says you have low disk space in some specific drive. When a drive capacity is full of data or nearly full, this message appears.
In order to solve this just free some space.
Answered By 590495 points N/A #314586
With that error, I don’t think you still have the 25 GB free space on your drive C because setup won’t trigger that error if the drive still has enough free space to use.
If you are in the process of installing apps on your computer or setting up your operating system, that 25 GB free space probably got consumed by the installers you copied to the drive and later deleted. Since you now only have 492 MB free space left on your system drive, you need to free up space by emptying the Recycle Bin.
Once the Recycle Bin is emptied, you should now be able to install the applications you need particularly your BEA app.
