Instructions Guide advises me to copy “JFSW.exe” to JetFlash
Instructions Guide advises me to copy "JFSW.exe" to JetFlash. I am not finding this to download. Please help. I have the JF V30 / 4 GB
Please connect first your Jet Flash to your PC and start Jet Flash elite again. If you already have your Jet Flash device connected you might have copied the JFSW2.exe file on the Jet Flash device and start it again from here.
Best Answer by Kevin Lee
Answered By 10 points N/A #199092
Hello Vanness,
JetFlash™
Features
  1. Fully compatible with Hi-Speed USB
  2. Easy Plug and Play
  3. Auto Login Function
  4. PC-Lock Function
  5. Favorites Function
  6. Secret-Zip Function
  7. E-Mail Function
  8. Data Backup Function
  9. My JetFlash
  10. Online Update
  11. Driverless
  12. USB powered.
For more detail information Please check this link.
Jetflash elite Problems & Solutions. Please check this link, here you will find you answer.
Hope this will solve your problem.
Thank you.
Answered By 0 points N/A #199093
Hi Stephen,
Before I go ahead and
give you the necessary link to download JFSW.exe to JetFlash I would like to briefly let you know why you faced this particular issue.
The Jet Flash comes with the necessary software basically the set up software in order to easily manage the data.
You can download the Jet Flash Setup from here.
