During the install of Kaspersky Security 8.0 for Microsoft Exchange Servers this error appears and if I click Retry the error appears again and also if I try to Ignore it the error reappears. The installer is downloaded from a trusted source and it should work. Does anyone have a solution for this error ? How can I solve this ?
Thank you !
The InstallTransportAgentActionStep operation returned and error: Executing…”}” failed ExitCode: 1, Timeouted: False, Output: Install-TransportAgent: The TransportAgentFactory type “Transport.AgentFactories.RoutingFilterFact…
Cancel Retry Ignore
I don’t think your operating system is supported since you are using Microsoft Windows 8 if you are installing the Management Console of Kaspersky Security 8.0 for Microsoft Exchange Server. This version doesn’t support the operating system because it is very modern and requires only a much lower version. If you are installing Kaspersky Security 8.0 for Microsoft Exchange Server on a non-server Microsoft Windows, it requires Windows XP Service Pack 2 x64 only, Windows XP Service Pack 3 x86 only, or Windows Vista both x86 and x64.
So if you need to use Kaspersky Security 8.0 for Microsoft Exchange Server, you need a computer that runs on any of the supported operating systems or replace your operating system. Before you install Kaspersky Security 8.0 for Microsoft Exchange Server, you need to install the following required components: Microsoft .NET Framework 3.5 Service Pack 1, SQL Server that is accessible on the network, and Microsoft Management Console 3.0.
Without these components, Kaspersky Security 8.0 for Microsoft Exchange Server will not run.
