Installing two Nokia PC Suite on Windows XP
Is it possible to install two Nokia Suites on one computer? This is for my Nokia 5800 XpressMusic and for my Nokia 6600.  Regards.
Best Answer by Sharath Reddy
Answered By 75 points N/A #118173
Hello Emily,
I am no so sure if that will be possible, and I am not sure why you will what to do that because I guess one nokia PC suites should be able to work for both of the mobile phones.
So just go to the internet and then download a nokia PC suite, and then install it on the computer. Try using it for both of the phones, one at a time and see what the response is. Both phones should be able to work with one nokia PC suite, so I do not see the need for you to download two of them.
Hope this helps.
__
Regards
Lee Hung
Answered By 590495 points N/A #118174
No, you cannot. I already tried it before because we have a Nokia 6610 and a Nokia N70 that both use Nokia PC Suite and each model has its own version and it didn’t work. You can only install one version of this application. If you try to install another version of Nokia PC Suite, it will check first which version is the latest or much higher.
If the one you are installing is older than the one that is already installed, setup wizard will inform you that a much recent version is already installed. Your installation will end at that point. There’s no problem actually even if you have different Nokia models. Both of them can use any versions of Nokia PC Suite.
In your case since you have a Nokia 5800 XpressMusic and a Nokia 6600, the version of Nokia PC Suite you need to install is the one from Nokia 5800 XpressMusic because Nokia 6600 is a bit older. Nokia 6600 was unveiled to the public in the fourth quarter of 2003 while Nokia 5800 XpressMusic was in October of 2008.
This is the Nokia 5800 XpressMusic.
This is the Nokia 6600.
