Installing HMA has Wrecked the COMODO on My System
Hello.
Somehow installing HMA has messed with my COMODO Firewall. I have had a great experience with COMODO Firewall and it has always stayed error free. But now when I have installed the HMA, its icon has disappeared from the system tray and I cannot seem to access it from anywhere. I have AVG installed on the system, but I am certain it has nothing to do with this.
I strongly believe that installing HMA has wrecked the COMODO on my system. Please let me know if you agree with me, and if you have a solution for it. Best case scenario is that I want to keep both of these software, with the help of minor tweaking of setting. Any suggestion is appreciated.
Thank you!!
Answered By 0 points N/A #154732
Hi.
I am not very sure with my answer since your post is not very specific. Please try to go to start and type "msconfig" if the computer is running in windows 7. If not, so to start, run and type "msconfig". system configuration will open and go to services and startup tabs. Make sure that the comodo services are selected. If not, check the service and click apply then ok. Restart the computer and then check.
You can also check the services. Just type services.msc on the search box when you click on start on windows 7 or go to start then run other windows OS. Make sure that the comodo services are running and in automatic. If not, go to the properties of the service and select automatic for the startup type. Click apply then start the service before clicking ok.
If there are services that you are not sure if its a comodo service or not, please go to this link for reference Comodo Help
