Installer error when booting up computer (using Windows XP SP3)
Hello experts.
I am using Windows XP Pro Service Pack 3.  Everything was working perfectly before until recently.  During the last two bootups, I got the following error message.  I have added an image but the image is too little, and you might not read it properly.  It says:
Installer.exe
Installer.exe has been encountered a problem and needs to close. We are sorry for the inconvenience
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
To see what data this report contains, click here.
I have to solve this problem. Please help.  Thanks a lot.
Best Answer by brionas brain
Answered By 25 points N/A #95891
I have possible solutions for the problem that you are encountering Please follow these steps or procedure for you to solve the problem that you are having.
1. Click Start and then go to the Control Panel.
2. Click on the Appearance and Themes and then click Display.
3. Click Advanced on the Settings tab.
4. Go to the Troubleshoot tab and then move the Hardware acceleration slider control up to the third place and then click OK
5. Click OK to close the window.
Answered By 0 points N/A #95892
You have two option to solve that kind of error:
The first option is go to Control Panel>Add and Remove Program "it is a trial and error"
First you must know what program are corrupted or conflict so you must uninstall all program you install in your PC and then Restart your PC
If the error appears again it is time to do the last option
The second option is reformat your PC.
Thanks
