I have been facing an issue while installing firmware 3.50. Actually, my Ps3 required to be fixed and for that I tried to update it but when it reached at around 20% of the installation process, it showed me an error sayingerror 8002F147. I even have tried to format the disk and install the older version. Now 2 months have been passed and I couldn’t use my Ps3. Please help me out in this matter. I would be very grateful to you.
Installation error in Firmware 3.0
How to resolve this one just simply try this if its work on your PS3 just to turn off your PS3 and then just hold the power button down and then simply the system will easily open or turn on the PS3 and then try to turn off again after that just simply re-press the you hand until you hear the 2 consecutive beeps from the your PS3 and then simply press the power button again to turn off the PS3 and then just simply prompted to plug in your controller via USB and then just simply hit the PS button from your PS3 just try that one.
Ben
