Information needed about PilotEdit Lite 5.6.0
Hello there everyone!
I have recently heard about the releases of the PilotEdit Lite 5.6.0 and am very enthusiastic to try it, but I am not sure about its reliability.
Can anyone tell me about how useful is it?
Please provide me the features available in the program.
Best Answer by Lelani Brones
Answered By 0 points N/A #153373
PilotEdit 5.6.0 is a remarkable replacement of a notepad as it overcomes may restrictions. The key advantage of using this application is that it can edit text, HTML, Java, PHP and hex files larger than 50 GB.
It also features an FTP/SFTP client that can download and upload over 4 GB files for online website development. It also provides the capability to edit, arrange, evaluate, combine, encrypt, and decrypt large files.
PilotEdit supports Windows platforms such as Windows 2000, Windows 2003, Windows XP, Windows Vista (32 and 64 bit), Windows 7 (32 and 64 bit), and Windows 2008. PilotEdit 5.6.0 can be downloaded for free.
Answered By 0 points N/A #153375
Hi Janis,
PilotEdit is an editing tool that overcomes restrictions of a Notepad in order for the user to work faster and better. The primary advantage of using this application is that it can open 50 GB file size. And also, if you are using this application for website development, there is a built-in FTP client that can be sued to work with online file that has 4 GB in size.
Also, there are no difference between the Lite version and Full version, but if you do spend some money on the application that you do gain extra features such as the ability to compare, encrypt and decrypt files as well as the option of working with SFTP for added security. This application is available for Windows XP, Vista (32 and 64-bit), Windows 7 (32 & 64 bits) and Windows 8 platforms.
Hope this information might be a great help for you.
Answered By 0 points N/A #153374
Hi Janis Caldwell,
PilotEdit Lite 5.6.0 is a text editing tool as well as it can be used as html editor, PHP editor or Java editor.
The key advantage of using the PilotEdit Lite 5.6.0 is the fact that it can be used to open huge files that are over 50 GB in size. If you are using the app for website development, there is a built in FTP client that can be used to work with online file over 4 GB in size.
Key Features of the PilotEdit Lite 5.6.0
  • PilotEdit provides the ability to edit, sort, compare, merge, encrypt and decrypt huge files.
  • Compare and merge two files larger than 500 MB.
  • Encrypt/decrypt files larger than 10 GB.
  • Edit an encrypted file transparently.
  • Sort a huge file larger than 1 GB.
  • Find/remove duplicate lines in a huge file larger than 1 GB.
PilotEdit Lite 5.6.0 works on both 32-bit and 64-bit Windows Operating Systems.
Amanda Morson
