Imported song in Power Point Presentation
Guys,
I made a power point presentation where I imported an audio file. But when the slide show starts, the song does not start until the effects have finished.
What should I do to start the song when the slide show begins?
Best Answer by Aeron Hogyu
Answered By 5 points N/A #121050
In order to play your imported sound file in your PowerPoint automatically as soon as the presentation starts, follow these simple steps:
  • Right-click the Imported sound file in your PowerPoint automatically icon and click on Custom animation.
Powerpoint Presentation add title
  • Select the drop down list beside your chosen sound and click on Start With Previous.
powerpoint effects
  • You may also click on Effect Options in order to modify the sound file more.
Powerpoint Create
  • Under the Effect Tab, click the From beginning option under Start Playing group. Or you may also opt to choose the From time: option and modify the seconds of delay before the song starts.
Powerpoint presentation creation
I hope this helps!
Answered By 15 points N/A #121051
Hi Dery,
Do you need to import an audio file? You can do it yourself by using below links.
They clearly guide to you.
DRM media converter interface
Given this link below represents a website, which has explained it by using photos. It will be attractive to you.
Last one, I have given below, is pretty good to understand by watching this video. Download and watch it, You can collect more information about your question.
https://www.gettyimages.com/music
