Import Wizard Unable to determined Guest Operating system
Hello everybody,
I am facing a problem when I try to import a virtual PC2004 Windows 2003 Server VMWARE in WMWARE Workstation 6.0.2. This error message always appears which you can see in the below attached image. Help me please to resolve this issue.
Windows2003 Server VMWARE Import Wizard Unable to determined Guest Operating system
Import Wizard
Answered By 10 points N/A #173724
This is a very common problem.
Solution:
1. You first need to make sure that the VM is not actively running on VMware Server.
2. Also, you ought to make sure that VMware Server does not have a lock on the VM’s files. You have to stop all VMware Server Services and/or reboot the (VMware) server.
3. Finally, it is a must that you have required permissions to the VM’s files.
Alternatively, the link might be helpful.
Hope that helps!
