No of visitors who read this post: 206
Category: Anti-Virus
Type: Question
No votes yet
I keep clicking “Import Outlook address book” in Avira Internet Security 2012 but I always fail. Another way to do it is to import Windows Mail but that’s also unavailable.
My MacBook Pro is relatively new. It runs with Windows 7 Pro 64-bit. It is equipped with a Boot Camp partition. I also added Office Professional Plus 2010 and recently did a remote full system repair using Microsoft Tech Support.
As you can see, I try my best to keep it safe and clean. That’s why I’m not expecting this error. If anybody knows the answer, please tell me.
Thanks!
Comment viewing options
Hi Bray,
It is exactly not any problem. It is a very familiar issue. To get rid of the problem what you will have to do:
Just call the Avira Customer Service and have Premium Products.
If once the premium product in your computer, you should have no problem.
Thanks for asking.
Hathy
# (Solution Accepted)
Hi Bray,
Your addressbook may be set to a property of read only. You might have to change this property manually. To get the step by step ways in which you shall change this, go to the link below which is from Microsoft as they had earlier solved a similar issue.
http://support.microsoft.com/kb/269777
For any further assistance on the issue, please notify microsoft or the publisher of your software
Carpenter harrer
