Hello.
Every time I try to connect with the version 7.10.500 of the ICA Client for Macintosh, the following error arises
Cannot find encryption module “EncRC5”. Session will be unencrypted.
Error Number: 8
What could be causing this? I have attached a screen shot too.
Please help.
Thanks a lot.
ICA Client for Mac Encryption Error Message
I think there is a missing component in your application that might have been corrupted or encountered an error and can not work. You may try restarting the application. Or if it doesn’t work, try uninstalling the application you are using and then install it back to fix any corrupted files in the installation and to restore its settings back to default including some that you might have been customized.
Try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, or Norton Utilities.
