I want to try program elan g myself, is it stable?
Has anybody here tried the new elan G system? I want to program elan g myself but I am quite unsure about the stability of the system. I have HomeLogic core software here and planning to try Elan G system using this.
Answered By 0 points N/A #147530
Hi Davis Avon,
Thanks for sharing your problem with us, I searched about ELAN G and I found that there is lot of new things in the new version. You can mix-up user interfaces in new ELAN G. It is an excellent product and it is not that much costly also means it is a mid range product. It can also handle your voice and e-mail messaging. If you manage to do some changes to installer then you can control any hardware you desire.
I hope this will help you.
