No of visitors who read this post: 205
Category: PHP
Type: Question
No votes yet
I want html code to split a pdf into image. I have the html code and I need the pdf file to be converted in the form of image. What is the procedure to convert it in the image and saving it the form of pdf file? I need help from an expert who is having the deep knowledge about it.
Comment viewing options
Hi Calistamadisonn,
You can split the PDF into image by using software.
You have to download the software from Internet.
I prefer the software named asHTML Code Export.
You can get it for free in: http://html-code-export.software.informer.com/
You can also use PDF to Image converter for completing your task.
I hope it will work.
# (Solution Accepted)
Hi Calistamadisonn,
There are several websites that can convert pdf files into image files such as GIFF, BMP,  JPG and etc.
Zarmar is probably the most well known file conversion sites. The process is very simple just choose the file to convert to (e.g JPG) then enter your email address to receive the converted fine then convert.
YouConvertIt (Beta) is another site that is similar to Zarmar. With this site you can upload 5 files at  the same time.
You can also use PDF converters. One example is the Universal Document Converter which is a software for converting PDF documents to graphical formats such as TIFF, JPEG, GIF, PNG, BMP, PCX, and DCX. You can download this software for free at: http://www.print-driver.com/download/.
Another software is the Pdf2image which you can download for free at: http://download.cnet.com/Pdf2image/3000-18497_4-10616351.html. While converting your PDF files to any desired graphical formats,  Pdf2image provides a wide range of applications to enhance image resolution as you wish.
I hope this will help you with your problem.
