King Lopezs
30 points
Posted on - 09/27/2012
Hi guys,
I received the error message while installing LabVIEW Internet Developer’s Toolkit 6.0.2 on my Macintosh.
At the present, a greater version of LabVIEW is running with my machine. So the problem regarding installing toolkit is unexpected.
Please help.
Install Failed
The following install step failed: run preflight script for Internet Toolkit 6.0.2. Contact the software manufacturer for assistance.
In order to get rid of this problem, you must
Change the LabVIEW Internet Toolkit installation directory in theDestination Select step of the toolkit installation wizard to the directory of the latest version of LabVIEW that you have installed.
This issue only occurs after the installation of version which is higher than 6.0.1.
For detailed assistance regarding this issue visit this page:
Hi King Lopezs,
I have reviewed your issue and find the best solution related to your issue.
If you want to install the lower version within same computer / Drive / Folder, You need to uninstall the previous / greater version.
Then you are able to install the lower version.
Another solution is that, you can change the folder at the time of installation.
Then software will not give the following errors a shown above.
I wish this solution may be helpful. Thanks!
Best,              Â
