No of visitors who read this post: 1024
Type: Question
Author: Gangothrim
No votes yet
I was using Lightworks on my 32-bit computer and had to shift it to a 64-bit computer that have more memory space. After few days. I received the error message “Unlicensed - Install License File". I have verified NTP date, uninstalled the old version and installed the latest version of Lightworks, provided new machine number and tried all the possible solutions.
Nothing worked. How can I resolve the error?
Comment viewing options
Please do try the steps below:
·         Uninstall Lightworks then restart the computer. Make sure that the LW folder on your Programs files is deleted as it may still store corrupted files there.
·         Reinstall Lightworks then restart the computer again.
Download the updates for Lightworks if after the reinstallation would not work.
As a work around, you may try to login as an Administrator and use the application. Warnings can be avoided by creating a task in the task scheduler. Make a shortcut to schtasks /run /tn "Your LW Task". Also, make sure that your Lightworks shortcut is pointing to the correct work directory.
