I need a reliable security check online program
What is a good security check online software or add-on when browsing unsecured websites and checking email?  I have received a lot of Win32 viruses in email attachments.  I need this as an add-on in my web browser then alert me when there is a threat.  I use Mozilla Firefox 18.0.2.  Thanks.
Best Answer by Nolan M Holford
Answered By 0 points N/A #138916
Torganwin32 or any other virus is automatically created day by day. We install many virus removal definitions or software but can’t get rid from this problem. We can remove this manually this method is more effective for removal of virus from pc by adopting following method.
1.   Go to safe method.
2.   Restart your PC, press continuously the F8 before launching the window.
3.   Then use the download arrow key to select the safe mode networking option and then do enter.
4.   Delete the files with are related to torjan.win32.badur.a
5.   Then click the start-menu-here type regedit and press enter key to activate the registry editor
Answered By 0 points N/A #138917
I think for an internet security, it is best to user AVG internet security it has lots of security features for the internet like detecting and stops viruses, threats and malware, it can stop unsecured link and file. It also prevents online spam and spammer; if you want to download it just follow this link https://www.avg.com/en-ww/internet-security. Hope this helps.
Answered By 0 points N/A #199241
Hello Brian,
There are lots of anti viruses that will do a decent job for you. You might have to buy the internet security versions because the basic or free versions do not offer complete packages. Here are some suggestions for you to try.
1. Avira antivirus
2. Kaspersky antivirus
3. Norton internet security
If you don't find them attractive you may try internet security software's. Here is the list of few best internet security software.
1. Bit defender internet security.
2. Comodo internet security.
3. Internet security suits.
Try any of them. You will find it useful for your work.
