guy blasi
30 points
Posted on - 02/21/2013
I would like to create a 3D presentation using a software. I'm new to this and I'm looking for a software that could make CSV formats into animated 3D data and tables. I need presentation 3D download for a Windows XP 64 bit OS.
I need Presentation 3d download for xp
Hi Guy,
You can create a 3D presentation using a website or a software. The most efficient software is Aurora 3D, you can use it with Windows XP. This software consist to create a new presentation or you can simply export your files CSV formats for example to the software and you tables and you can use them.
Douglas
Hello Mr. Guy,
You can create 3D presentations of your CSV files by using the following software:
Tao Presentations Discovery : A Greatly optimized tool for 3D dynamic and interactive presentation with various effects to choose from.
This is the only free available 3D presentation tool I could find for you. If you are interested in paid software then check out this review on the Top 5 Tools For Creating 3D Presentations. Hope this helps.
Best regards.
Here's some of the 3D software you might consider for your data presentation:
Best regards,
