I need a partition wizard for DOS NTFS
Hi guys,
I'm looking for a partition wizard for DOS NTFS. I need to partition my hard disk and resize NTFS and can run in a DOS environment. I'm on Windows XP 64 bit SP2. Any ideas or suggestions?
Best Answer by Jose D Dunn
Answered By 10 points N/A #172980
Hi Fernando W Alvarez,
You can use Minitool Partition Wizard. This partition wizard has a feature which will make your work easier and very much faster about partitioning a hard drive. This software is also free which makes this more attractive to use. You can download this at their website.
Or download it here for free:
