I need HP 2311xi monitor details
I want to buy a new monitor, when I asked my friends, they suggest HP's new 23xi model.
I heard its new and it has some advanced features. So I want some details about it.
I want to know its native resolution, weight, power consumption and dimensions (WHD)
Thank you in advance.
Best Answer by Chad Wiker
Answered By 0 points N/A #137568
This monitor is best suited for surfing internet, viewing videos, etc. The technology used is LED (Uses Light emitting diodes and hence a better black is produced and hence the monitor will have really high dynamic contrast and very sharp clarity.
The details of the monitor are:
Display size : 23”
Resolution : 1920 x 1080
Color 68% of NTSC
Brightness 250 CD/m2
Contrast ratio 1000 : 1 static; 3000000:1 dynamic
Weight : 3.91 kg
Dimensions 58.49 x 12.59 x 39.70 cm
Power consumption 33W
Connectivity : Can be connected to a desktop or notebook with VGA or DVI-D and HDMA with HDCP support.
Answered By 0 points N/A #137569
Based on my comprehensive research about HP 2311xi monitor, this 23-inch monitor features the new IPS LED Technology (In-Plane Switching Technology), that gives a very wide angle screen, the screen offers a 1920×1080 resolution with response time of 1000:1 contrast ratio, 7ms GtG response rate, 16.9 aspect ratio ; the connections include HDMI, DVI and VGA with (HDCP support). It has color temperature 5 presets and RGB adjustment, it has high color saturation it has an impressive viewing angle of 178º, it measures 416.5mm height 557.95mm width 159mm dimension and it weighs 9.25 lbs., this monitor is energy star compliant and it only consumes 33watts max power consumption.
Consumes 33watts max power consumption
