I need help in AutoCAD hand bag
Hello there.  I'm an aspiring designer and I would like some help designing a hand bag using AutoCAD.  I'm a new user of AutoCAD so please bear with me.  I want to design an AutoCAD hand bag in 2D and 3D models.  I have AutoCAD LT 2010 and Windows Vista 64 bit.  Thanks in advance.
Best Answer by Bradford Senior
Answered By 0 points N/A #130999
Hi!
I can give you some tutorial links for AutoCad LT 2010.
AutoCAD LT Release 2010 Tutorial from Autodesk Website
Video Tutorials for AutoCad LT 2010 – some basic video tutorials for AutoCad LT 2010.
Free AutoCAD 2010 Tutorials – in this website, they have a demo on solid modeling, 3D printing and Mesh Modeling that can help you creating the handbag.
Complete Course for AutoCad Beginners – this is a great tutorial, from the basics of typing of commands to 3D layout. This one is good for you since you are just starting with AutoCad. Its like attending a class because its divided in lessons and there are quizzes after each level.
And if you want some ready made handbag .dwg files, you can download it here.
Handbag .dwg files
AutoCad Blocks
But its more fun to learn how and create your own cad drawings.
Answered By 0 points N/A #131001
Hello Stacy,
It is really important to understand the procedure of using the AutoCAD software perfectly, if you are willing to work professionally. AutoCAD using is completely related with architectures and engineers who use it for creating a 3D model structure which should look perfect shape from all directions. I want to provide you some valuable links which might help you to accomplish your task.
Tutorial of AutoCAD and creating description of 3 dimension
This link will provide you elaborate description of overall AutoCAD system. But I think by watching you might get better ideas so I am also providing you a video tutorial.
I hope my tips will help you to complete the task.
Good luck.
Answered By 15 points N/A #131002
There are many tutorials that you can find on the Internet. First of all, you need to have the AutoCAD LT 2010 with all the updates installed on your computer. This is to ensure that you will have the latest features which you can use in designing your own handbag. You can click on the link for the AutoCAD 2010 updates and service packs:
For a complete list of tutorials using AutoCAD LT 2010, go to the link. This is best especially for beginners like you.
Answered By 0 points N/A #131003
There are lots of things to remember in AutoCAD 2010 before you can start making your very own design. Every drawing made in AutoCAD is exact. You need to know the measurements and the points, the common drawing commands, zooming and panning of your design and more. Your design should have an origin wherein added objects should be related to it.
For this, you can find many information and tutorials online. Click on the link below to know more or watch the video attached below and gather all the information so you can make your handbag design.
AutoCAD Tutorials
[video:http://www.youtube.com/watch?v=NNVbbtOSQV8 autoplay:0]
Answered By 45 points N/A #131000
Hello Stacy,
It looks like you need help to design a handbag in AutoCAD. What you need is a few tutorial which will help you to get the basic idea of designing in AutoCAD. These tutorials will help you to understand many features of this software that enable you to create precise drawings quickly and easily. I have a link for you where you can find this tutorial
If you want some video tutorials you can find it in the web very easily because AutoCAD is a very popular and widely used software. You can try this link
I hope this helps.
