I need a file hash check windows shell compatible program
What do you recommend for a file hash check windows shell compatible program? I found HashCheck and HashTab, HashCheck is compatible with SFV (for CRC32) and MD5, HashTab mentions MD5, SHA1, RipeMD, etc. but doesn't mention CRC32. What do you suggest?
Answered By 5 points N/A #171423
CyoHash is the answer to your problem. It is a simple tool which is used for calculating the MD5 hash, SHA1 hash, or CRC32 checksum for a file. I believe you need to calculate the md5/sha/crc32 , if this is the case, then you definitely need this tool. It also comes with an installer which makes life easier.
 http://heanet.dl.sourceforge.net/project/cyohash/1.0.11/CyoHash.exe You can download it from this site
