I need auto movements recorder screen software
Hello everyone,
I am facing a problem. Recently I need a recorder which will record auto movements of screen. Is there any software of auto movements recorder screen for PC? Please give some reply.
Thanks in advance.
Best Answer by Michael D Dent
Answered By 5 points N/A #199308
You can use the Wondershare DemoCreator. It captures and records screen activities. This is a very powerful tool than can let you capture your desktop activities for Windows PC. You can just simply Record, Edit and then Publish your video. Download and purchase it from the link below:
https://www.wondershare.com/pro/democreator.html
Answered By 40 points N/A #129737
I found the best screen recorder on the internet, and it's free.  This application is called Ezvid.  You can use this application to record your computer movements, also you can make great screencast videos which are ready for YouTube.  Although it is free, this application is best for normal users who don't need extra options.  I hope I helped.  Regards.
