I need an accurate Dsl speed counter software
I recently subscribed to a 1Mbps speed DSL connection.  I'm only getting around 70-80 kbps download speed.  Is there an accurate DSL speed counter software for performance measurement and configuration?  I find the speed too slow.  I am also subscribed with another ISP, also with 1 Mbps speed, and I'm getting around 150-180 kbps download speed.
Answered By 10 points N/A #171960
Hi Sean A Harwood,
You can download many from websites then choose one. Usually maximum “DSL speed counter software” count actual speed. So, you need the best “DSL speed counter software”. Depend on internet ranking I am giving you a software name which is “DSL Speed”. I think after using this software you will get the correct speed rate.
Here I am giving you a download link-
http://dsl-speed.software.informer.com/
You can download from here.
Good luck
