I am having trouble reloading movies into my ZBrush
I had just finished the task of recording a very lengthy video shoot for future production and was preparing to reload into my ZBrush installed in my 32-bit computer which has 16MB of RAM and a 2.66 GHz processor. In the process of reloading it, I got the error message below. Help me out.
MEMORY ERROR
ZBrush will attempt to recover from this error but it may not always be possible. In future sessions, please reduce the density of the edited mesh or increase the amount of available memory.
Best Answer by EthelynMillikin
Answered By 0 points N/A #124077
Hi Djuna,
Zbrush is a resource consuming application. For smooth operation is requires both processing power and sufficient amount of RAM and a large size Graphics card installed in the system. Otherwise, high definition videos can’t be loaded for editing and rendering into a production output. Your problem is insufficient system memory. You need to add both Main Memory (RAM) and Video Memory (a larger size of graphics card of 1GB of graphics ram). I recommend you to have 4 GB of main memory (ram) and 1 GB of graphics card.
Answered By 15 points N/A #124079
You have memory problem. Z-brush is resource consuming applications which take a lot of space and processing. For make it operating good and proper it requires an upgraded system with good ram and a good graphic card to load the high definition videos. Your error is insufficient memory. Add Main Memory (RAM) and Video Memory which needs a larger size of graphics card of 1GB of graphics ram.
4 GB of main memory and 1 GB of graphics card will be goodbye increasing both of your memory’s your problem will be solved.
