I have a problem with Nero 10 on Windows 7
Until yesterday, Nero 10 was running ok and no issues were found. I tried to make an audio CD for my car. I added the songs, selected the burn speed and everything. The program started creating my audio CD. At 89% it stopped, told me that The Burn process failed at 4X speed. So I tried again, changing the speed, but I got the same result. Do you guys have any idea why do I encounter this problem with Nero 10 because I have searched online and it seems like I am the only one with this issue.
Best Answer by Sharath Reddy
Answered By 0 points N/A #173951
It may be a hardware fault as it is common with Nero products.
A simple uninstall and reinstall may solve the issue.
Or you can use other burning software like IMGBurn.
Answered By 590495 points N/A #173952
There are really different reasons why you encounter a failed CD burn. Sometimes the error is caused by a problem in the hardware which obviously directs you to your optical drive or the CD/DVD drive installed on your computer. If you are using a somewhat old optical device then you shouldn’t wonder why it happened.
This problem is also very common especially if you frequently burn CDs before. Purchasing a new optical drive will surely fix the problem. Another possible reason is the media you used to burn the content. Sometimes the CD is already damaged or defective even if it is newly purchased. Common CD defects will sometimes prevent the computer from recognizing the disc after inserting it in the optical drive.
In cases like this, the entire disc is already corrupted. You can return the CD to the store if it is defective to replace it. Sometimes you should also check if the source media is still ok because if there is already something not right in the source files then you will also have a failed burn.
Another way of fixing the problem is to use a different program to burn your content. Try using CyberLink Power2Go 9 Platinum. This new version will not only allow you to burn audio CDs but will also allow you to burn Blu-ray, DVD, and BDXL discs. It also includes ISO tools and 256-bit disc encryption.
