I have an idea to create a website that is interactive
I think I might need to create software but not sure, willing to learn!! I have an idea to create a website that is interactive. An example of what I am interested in would be a list of family birthdays in the left column and a calendar in the center. Is there an adobe program that allows me to create something like this? I would like the user to be able to drag and drop the birthday to the correct day on the calendar.
Answered By 0 points N/A #113092
Hello Tashi
This is a good idea to celebrate your birthday rather your family. Yes you can get help from Adobe professional software. i will share you..Let follow then
At first you have to know about Adobe DreamWeaver program which is the foundation to make a website easily. If you have enough knowledge, you can do it early. Creating table coding which is best to the calendar. only adobe can serve you by giving instructions.
But if you good at HTML or CSS work you can create a website within 1 or 2 hour and watch over the internet. So have a good decision. Thanks
