No of visitors who read this post: 402
Category: Anti-Virus
Type: Question
No votes yet
Hello everybody,
I have installed AIS on Windows 7 64bit and works well but I get an error after the reboot and once Avast! 7 AIS started.
It seems to be all working well but I have no idea of the error message.
Please give me your suggestions.
Screenshot has been attached below.
Thank you all.
AvastUI.exe - Application Error
The instruction at 0x77e98dc9 referenced memory at 0x00000014. The memory could not be written.
Click on OK to terminate the program.
Comment viewing options
Hi Michael,
This problem is usually caused by one of the protective features of your system which is the Date Execution Prevention (DEP).
DEP is all about preventing some regions of your memory to be written to. To fix your problem you can either turn Data Execution Prevention off or to add your program to the exceptions list. Here is how to do it
- Go to Control panel --> System --> Advanced --> Performance settings --> Data Execution Prevention Tab --> Then choose Turn on DEP for all programs and services Except for those i choose --> Add and browse for the executable of Avast and select it.
Now reboot and your program should work with no problems.
Hope this helps.
