I experienced a fatal error
Hello guys,
I experienced a fatal error last Wednesday. I proceeded to investigate the source of the error and found the event viewer log file for the error which I have posted below.
It says that the source is the SChannel which is a security channel according.
The following fatal alert was generated 48 The internal error state is 552
Best Answer by LyanaHay
Answered By 0 points N/A #192310
Hello King,
An error like the one you are getting sometimes occurs immediately following the installation of a new Metro app. Such errors also are always preceded by a couple seconds by the following information level event: "The Software Protection service entered the running state."
The problem is more likely to be with SP.
Nicke
Answered By 0 points N/A #192311
Hi  King Lopezs,
  The message indicates the computer received an SSL fatal alert message from the server.
 It may happen when you try to install third party software.
Solution:
1] Try managing SSL for Client Access Server
2] Check settings for SSL server
3] Check whether you have set up SSL server very well.
These things should solve your problem.
