I can’t remove the grid lines in my word document
I am encoding on my word document.  When I saved the document.  I accidentally clicked on something and asked to me to save and then I click "yes".  Then my documents are full of grid lines.  It's kind of annoying while I am encoding texts.  How can I remove it?
Ammalyn
Answered By 0 points N/A #87593
Hello friend,
You maybe a new user of MS office word. Though you can simply solve this problem by view option in the MS word document file. At first you have to open the word document file in the MS office word then you will see different formatting option such as insert, page layout, references, mailings, review, view and add-ins tab in up of the window. Now you only have to click the view tab, and you will find some other options like ruler, document map, gridlines, thumbnails etc. And you can solve your problem only by reselecting the gridlines. The following image maybe helpful so see it clearly.
Hope this will help you to remove your problem.
~Mojnu~
