I cannot connect to HaMachi pls help!
I have a hamachi server that I am trying to connect to. I am getting an warning symbol in the form of a yellow triangle that has an exclamation point on it. When I tried to right click on a network name that is available and selected the settings from its options, it would say that there is a problem with the network adapter.
I have already reinstalled the adapter, turned off the firewall but still I am getting an error and I still cannot connect to the server. Your assistance on this problem will be appreciated. Thank you.
Answered By 0 points N/A #107025
To connect hamachi server you should follow this
1. In the Hamachi interface, go to System > Preferences > Settings. Be sure you are in Advanced Settings.
2. Scroll to Disk Locations and click on Service configuration to emphasize it.
3. Click the Open button. If you cannot open frankly from here, find the way to that folder during Windows Explorer.
4. Open the Run box by burning the Windows key and the R key at the same time.
5. In the Run box type: Services.msc and press Enter or click OK.
6. In the services list, find the LogMeIn Hamachi Tunneling Engine and turn it off.
7. Just the once that repair is off, delete the inside of the Service Configuration folder you opened previous.
8. One time deleted, start the Tunneling Engine service back up, and it will reconstruct new files.
Answered By 590495 points N/A #327932
If your Hamachi client can’t connect to the Hamachi network adapter, you may receive the following message:
Failed to connect to the adapter
This means there is a failure in the Hamachi network adapter. First, try to uninstall and reinstall Hamachi. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select your Hamachi client among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo then install Hamachi back. You can also download the latest client from Hamachi VPN Client. If this doesn’t work, try disabling your firewall if you are using a third-party firewall except Windows Firewall. Restart the computer then try again.
If this doesn’t fix the problem, right-click “My Computer” then select “Properties.” Go to “Hardware” tab then click “Device Manager.” On the next screen, expand “Network adapters” then manually enable the driver for “Hamachi Network Interface.” After this, start Hamachi again then see if it works.
