I can’t open any .swf files from Photoshop
Hello Friends,
I can’t open any .swf files from Photoshop. I’m getting several scan error in my event viewer. Is it possible that I’m affected by a virus? My FPROT antivirus can’t seem to fix the error I’m getting and I can’t see any related articles online.
Event Type:   Information
Event Source:   F-PROT Antivirus
Event Category:   Scanner
Event ID:   4096
Date:      05/03/2012
Time:      10:16:30 AM
User:      NT AUTHORITYSYSTEM
Computer:   IT03
Description:
An unknown error occurred while scanning file C:Documents and SettingsAll UsersApplication DataAdobePhotoshop Elements10.0Localeen_usWorkflow PanelsmodulesPhotoStack.swf
Best Answer by Skarbos Jay
Answered By 0 points N/A #146977
I would like to inform you that the .swf cannot be opened by any Photoshop applications. You’ll need to download and install the Adobe Flash Player from the Adobe website http://www.adobe.com  it is a freeware and can open .swf files on your computer.
If the Antivirus program installed on your computer is not detecting threats, try updating it manually. If it does not get updated, please make sure your computer’s date and time is correctly set. Still if it does not help, try installing another Antivirus program like Eset NOD, McAfee, Avira, Avast, Norton. These are very good and popular Antivirus programs.
Thanks and regards,
Skarbos Jay.
Answered By 5 points N/A #146976
Are you trying to open .swf to Adobe Photoshop? Is that what you meant? And if that’s the case then you’re attempting open an incorrect file format. Try using Adobe Flash Player or Adobe Shockwave. Download it here:
Adobe Flash Player : get.adobe.com/flashplayer
Click on Agree and Install Now
Adobe Shock Wave: get.adobe.com/shockwave
Hope this will help.
Answered By 590495 points N/A #146978
The SWF or “.swf” file extension is a Shockwave Flash file format. It was originally by Macromedia and is now owned by Adobe. The letters “SWF” means “Small Web Format”. This file may contain video and vector-based animations and sound. This file format is designed for efficiency in delivering content over the web.
You can view SWF files using a web browser but to do that, you need to install Flash Player which is then used by the web browser to play SWF and other flash media content. There are different versions of the Flash Player plug-in according to web browsers. You can download the following Flash Player versions depending on the web browser you are using:
At the moment, the latest PPAPI version has a bug discovered several weeks ago. The latest Adobe Flash Player 23.0.0.162 PPAPI version breaks on Opera and you will not be able to play Flash media content on your web browser. As a workaround, install the previous version Flash Player PPAPI 22.0.0.209.
