Good day everyone,
I am a new mac user and currently working on a pdf project. I would just want to ask if there is an available pdf text encoder for mac that is free to download and is easy to use? Thank you very much as your answer would really mean a lot.
I am looking for PDF text encoder for Mac
Hello Laura!
I found two PDF text encoder that may prove useful for your needs.
1. PDF Creator Master for Mac – It is an easy to use software that is able to create PDF files from simple text and even images It has several features wherein you can modify the PDF file to include encryption as well as passwords. For a more detailed description you can check out this link: https://pdf-creator-mac.en.softonic.com/mac
2. Combine PDFs – This is a software that may be used to combine multiple PDF files into one. This will be helpful in combining separate and related PDF files into one for a more convenient and organized feel. For more details on the software, you can look it up at: https://combine-pdfs.en.softonic.com/mac
Hope that helps!
