HP LaserJet color printer CP5225 stops Printing and shows Error 55.0601
My HP LaserJet color printer CP5225 keeps getting a problem in the midway of printing a page and stops working then showing a message error 55.0601. I reconnected the device with my pc for solution but failed. Please kindly provide the possible solution of this problem for me.
Answered By 0 points N/A #151377
For this problem, you can try out these four solutions I recommend. Usually, having this error is caused by an internal hardware malfunction. You can first try turning off the power and wait for thirty seconds before turning it on again. Just patiently wait for the printer to set up and initialize.
If that fails, the problem might be with the connector, it might be jammed. Check the connector and remember to always remove the orange tab in the cartridge if it is new. If those solutions still don't work, I advise that you call the HP technical support to help with your problem because it might be something that you can't fix by yourself.
During worst case scenarios, replacing your printer would be cheaper than getting it fixed.
