Hp laserjet 6l 32 bit Windows 7 driver problem
My printer worked perfectly fine on Windows xp.
I recently installed Windows 7 and that's when the problem started.  It could not detect my printer.
I updated the windows 7 32 bit driver and still the same problem.
Would the 64 bit driver work?
Where can I download a working hp laserjet 6l 32 bit windows 7 driver?
Answered By 270 points N/A #196184
Hi there John,
Your problem is most likely caused by incompatible driver installation and yes you need a new driver to make your printer work. I have here two websites where you can easily download your driver requirement for free:
1. CNet download Central Website
2. XP Drivers' Website
Both of these websites don't need any registration to be able to download and they are directly from HP.
Hope this works for you.
Waall Mike
