AS I am trying to install the software for my HP Color LaserJet 2600n. It is getting an error which says, spooler subsystem app error. Why am i seeing this error? And how do I solve it?
Spooler Subsystem App
Spooler Subsystem App has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in middle of something, the information you were working on might be lost.
To get rid of the problem you need to do the following:
Download and install 'HP Port Monitor 7.1.3.31 Patch'
After downloading select Download Drivers and Software and then select your operating system.
I think you know a Microsoft Fix it Wizard is available now and that will resolve several spooler related errors.
This will restore the print spooler to default setting.
I think your problem will be solved.
Hathy
