How to wrap bootable CD dvd with paper?
Hi. I have many discs containing important softwares and there is a problem how to keep them save. For the safety  I want to wrap bootable CD dvd with A4 paper. What is the proper way to wrap and protect them.
Best Answer by Jose D Dunn
Answered By 10 points N/A #148087
Hi Nicholas Kevinn,
If you want to protect your CD/DVD and the software it contains. I had a better suggestion for you. First, use CD Bags, Wallets or Cases instead of A4 paper which will be troublesome if you want to use your CD/DVD. Second, you can back up your software, create images or ISO files using NERO or Ashampoo burning studio. In this process your software is very much safe even if the CD/DVD was damaged or broken. I hope this will help you.
Jose D Dunn
Answered By 35 points N/A #148088
As jose said use cd bags or covers, which will prevent your cd/dvd from getting scratched. A couple of minor scratches are ok, but major disk scratches would lead to disk read problems.
If you are more concerned about keeping your data safe, then I would suggest you to go for ONLINE BACKUP. Check out some sites like
http://www.mypcbackup.com/
https://www.idrive.com/
Joseph S Peterson
