How to view and remove history from cisco router?
Hi, I want to clean up internet browsing history on our router. I need to know how I can see and remove history from cisco router. I don’t exactly know how to do it so I need your instructions. Your will be very much appreciated.
Answered By 5 points N/A #163782
Hi Jennifer,
To see the internet browsing history of your cisco router you should enable the Logging feature on your Cisco Router. When you login to the Router setup page, click the “Administration tab” and after that, Click also on the sub tab “Log” below so that it enable the logging feature on your cisco router and let you to see/view the internet browsing history where you can delete them.
Hope it will help you.
