How to use a USB mouse on android devices?
I am using an Android based Tablet. I want to attach a mouse with it. I searched on the internet about USB mouse Android but did not get satisfactory results.  I have to ask a question for the experts, can I use a USB mouse on Android based devices?
Thanks in advance for your helps.
Best Answer by Pagee Stephen
Answered By 0 points N/A #181873
Hi
Yes you can use the mouse on your Tablet by using USB or Bluetooth just as you use it on your personal computer or laptop. You have not mentioned the model of your device, but in general you have to purchase an adapter or if you want to connect keyboard and other input devices purchase USB Hub that will also decrease the load on your Tablet battery.
Thanks
Answered By 0 points N/A #181874
Hi Kurtra,
As you want to use mouse in your Android-powered tablet, I have good news for you. You can easily use mouse in your tablet, just like you do in computer. Plug in your USB mouse to your tablet. Simple as that. You don't need any kind of software or anything. Plug in the mouse and move it, a cursor will appear which will give you the exact same feeling of using a computer. You can read this in more detail in the official Google Android Hardware Page.
Regards
Answered By 590495 points N/A #326318
Connecting a mouse to an Android device is one remedy when the touchscreen display is broken. If the screen of your device is frozen or non-responsive, there is a workaround that will make navigation possible. You need a USB mouse and a USB On-the-Go (OTG) cable for Android like this one: OTG Cable for Android. Since the touchscreen is frozen, navigation by touch is not possible.
With the use of the mouse and the OTG cable, you can make navigation on your device possible. Connect the USB mouse to the OTG cable and the OTG cable to your Android device. Now, see if you can navigate your way around your device.
