How to use exchange Facebook likes software ?
Hi Experts,
I am using exchange Facebook likes software to increase my Facebook likes. The reference was not given with it. Can any expert advice me on how to use this software.
Olaandoaddison
Best Answer by Sharath Reddy
Answered By 590495 points N/A #131353
I’m not sure if the program I found is the same application you were using but if not, they still have the same functions and purpose. I was able to find Exchange System Script 5 which is used to exchange system with Twitter, Facebook, YouTube, Google, and web traffic. This script is a powerful exchange system for the mentioned websites. The program has many features like:
  • Exchange systems for:
    • Google +1
    • Twitter Followers
    • Facebook Likes
    • YouTube Views
  • Traffic exchange
  • Auto-Surf bar for traffic exchange with anti-frame breaker
  • And more
This Exchange System Script 5 application is priced at $19.95 and supports Linux, Linux Gnome, Linux Open-Source, Mac OS X, MS-DOS, Unix, Windows 2000, Windows 98, Windows XP, Windows Vista, Windows 7, and Windows Mobile. You can download Exchange System Script 5 from International Software Industry Association — Exchange System Script 5.
Answered By 0 points N/A #131354
Hello Orlaandoaddison
I wanted to tell you that as such there is no documentation prepared for the said software. But it is easy to use and once you start it, you will come to know about the usage. If still not helping then you can ask your friend or colleague.
Or alternatively you can install other software and win 100 free coins also.
Follow the link https://www.fanslave.com/
