I prepare many reports using Microsoft word. When preparing I use header footer option. But my question is the same header footer is appearing on all pages. Can’t I use different header/ footer in several pages?
You can actually do that. A different header or footer.
I will explain how to add and remove headers and footer.
On the View Menu of your Word Program, Click Header and Footer. After that you can notice that you cannot edit the body of the document and you are presented an area above and below the page. In that Area, you can edit the header and footer of the documents.
Header and Footer can be change according to the following categories:
1. You can have Headers and Footers for the First page only
2. You can have a different Headers and Footers on an Odd and Even Pages.
3. You can also have different headers and footers for sections of a Document.
For more information on the details of how to perform it. Please refer to support.microsoft.com
http://support.microsoft.com/kb/211432
Loida Arcel
Yes you can have different header /footer in Microsoft word. However, in order to have different header/footer you have to break the entire document in to sections according to place that you want to change it. I will explain it through an example.
I will take a word sheet with four pages and break it to 2 sections. That means page 1 and 2 are one section. Page 2& 3 are another section.
In order to break sections, first click on the 2nd page, click on the Page Layout tab and click on the Breaks.
Now click on the next page in the section breaks.
Now click on the first page, click on the insert tab, click on the Header and click on the edit header.
Type the first header that you want. I will type it as “header 1”.
Now click on the third page and in the same way go to the edit header.
Then click on the “Link to previous” in order to disable the link with previous section.
Then edit the header as “Header 2”.
Now you can see that there are 2 headers in page 2 & 3.
It is possible to have different headers and footer in a word document, but you will need to your document into separate sections in order to break the connection because word maintains the default header and footer throughout the document when you first create the header and footer. So it is important to first break this connection by having different section of the document. You can do this by following these steps;
These settings will automatically be applied to all the headers and footers in the subsequent sections. Repeat the above steps in case you want different headers and footer for these sections. Also check out the Microsoft help or the website.
