How to use desktop PDF convertor online?
Hello Techyv members. I hope everything is fine. I would like to ask how to use desktop pdf convertor online. I would really appreciate if you will give me a step by step guide for this. I'll be looking forward for your answers and suggestions. Thank you so much for the help.
Best Answer by Graham Mcnatt
Answered By 0 points N/A #143797
Hi Rodrigez,
You have many web sites that provide a solution to convert your documents to PDF online.
one of those site : https://en.conv2pdf.com/
Here are steps you need to follow :
1- Browse for the file you want to convert on you computer.
2- Change your document's right – it is an option.
3- Convert – generally you will have a button called 'convert' that you should click on.
Kind regards,
Answered By 5 points N/A #143798
You can convert your PDF file to PowerPoint, Word, Excel, Email and other file format online at this site https://www.freepdfconvert.com/
Follow these steps for easy conversion:
1. Click "Select"
2. Choose a URL or file that you want to convert
3. Write your email add where you will receive the file converted but this is optional
4. Choose the file format you want
5. Click convert to start the conversion the  you will automatically receive the file in your email.
