How to upgrade Android version of HCL ME1?
Hi guys,
I have HCL ME 1 smart phone and I want to upgrade its Android 1 software. I don't even know what is the Android version currently my HCL ME 1 smartphone is running on. But the handset is becoming quite slow so I thought upgrading it may work. So please tell me how to upgrade its Android version.
Answered By 590495 points N/A #186874
I guess you need to check your Smartphone first before doing an update on the operating system. Updating the Android version of your handset will not make your device faster because it has nothing to do with it. If you want to make your phone a little faster, you should install an app that will clean the system from unwanted files.
Try installing Clean Master Phone Boost on your Android phone. This app will help you free up some space in your internal storage, boost memory, improve the speed, and protect your Smartphone against vulnerabilities and malicious applications.
One of its features is the Device Cooler. This feature helps cool down your device by searching and stopping the applications that are causing it to overheat. Another feature is the CPU Boost. It determines how much CPU is being utilized by applications on your Smartphone. It stops applications from wasting battery which slows down your device and cause overheating.
