No of visitors who read this post: 252
Category: Anti-Virus
Type: Question
Author: Syed ahmad
Your rating: None Average: 5 (1 vote)
 I have Panda Cloud Antivirus 1.5.1 in my computer at home. I have another computer in my office where i have installed the same antivirus from cd. But there is no internet connection in my office. So how can I update my office antivirus by using any usb or cd?
Comment viewing options
# (Solution Accepted)
hi friend,
let me answer your question for panda cloud antivirus you don't need to have a internet connection, its not a must. if you having internet connection you can protect data from your cloud antivirus. the update method for cloud is not clear, but without internet connection your cloud virus guard is capable of protecting your data. and for the moment there is no manual way to update cloud antivirus by using offline update files
thanks
Hallo Syed Ahmad,
You can download the updates for the panda cloud antivirus from somewhere else and the use a flash disk to transfer it to the computer in your office. On google, just search for panda cloud antivirus updates, and then look for the links to find the right update and then download it. Or go to www.majorgeeks.com and download the update from there.
Once you have downloaded it, transfer it to a flash drive which you will use it to transfer the update to the office computer. On the office computer you will open the panda cloud antivirus and then in the menu bar, look for the option for updating the antivirus from a directory and then trace the location where you have saved the update.
__
Regards
Clair Charles
