No of visitors who read this post: 329
Type: Question
No votes yet
I recently bought a Motorola XT720 Android Phone from South Korea.
The problem is that it's locked to a mobile network in Korea.
Is there a way that I can unlock (openline) my phone using some apps available online?
I asked a phone specialist but it costs a fortune. Is there a way I can do this on my own?
Comment viewing options
# (Solution Accepted)
Yes, you can unlock online. There are several websites that teach you how to unlock the Motorola XT720. Basically, all of them requires you to turn off the phone, remove sim card, turn on the phone, then enter unlock code.
The bottom line is that you need to purchase the unlock code through them. Well, it’s up to you, where is cheaper and safer (meaning your phone will not get busted.)
You can unlock your Motorola XT720 locked to southkorea network in this site TheUnlockarena.com  using unlock codes.
To get code here  you must specify the following information.
  * Your mobile phone manufacturer name and model number
 *The name of the network or service provider your mobile phone is currently locked to
  *The IMEI Number of your mobile phone
